Date September 11 (Tue) to 16 (Sun), 2012
Venue “Messe Frankfurt”,
Frankfurt, Germany
NTN-SNR booth Booth A30/B31, Hall 2.0
Link to the official site
http://automechanika.messefrankfurt.com/frankfurt/en/besucher/willkommen.html
NTN-SNR will run a booth at “Automechanika” the largest automotive aftermarket exhibition in Europe, with the theme “Innovation and R&D” In addition to wheel bearings with sensors, a wide range of aftermarket products will be on display, including engine timing belts, auxiliary boots, auto-tensioners and water pump kits. NTN’s demonstration vehicle “Q’mo” equipped with a range of EV system products, will be on stage conducting test drives, highlighting its special “Pivot turn” and “Lateral move” functionality. We look forward to seeing you at the event.
Main exhibits
1. Wheel Bearing With ASB Technology
2. Timing Kit
3. Timing Kit With Water Pump
4. Suspension Kit
5. Brake Disc With Integrated NTN-SNR Bearing
6. In-Wheel Motor System Concept “Q’mo”
7. Two-seater Compact EV Equipped With The In-Wheel Motor
* The design of the exhibited EV differs from this vehicle in above photo.
Source: NTN
